ENTERTAINMENT DATA PASS ON EE BUSINESS
With the Entertainment Data Pass you can enjoy endless entertainment streaming without denting your data.
How does the Entertainment Data Pass work?
The Entertainment Data Pass will cover the data you use when you're streaming content and music from any of our chosen content providers listed below. This means you can stream music and video without using any of your plan’s data.
You can select the Entertainment Data Pass as an Inclusive Extra. Entertainment Data Pass stays on your account until you remove it or select another Inclusive Extra, which you can do every 30 days.
What’s not included?
The Entertainment Data Pass doesn’t cover:
  • Data that’s required for things like accessing or browsing the content provider’s app or for any adverts within an app.
  • If you’re using iOS 15 with iCloud Private Relay switched on, some or all of the data used while streaming content won’t be zero-rated. This feature stops us from linking your EE customer ID to all of your activity.
How do I get the Entertainment Data Pass?
With an eligible plan you can select the pass as your Inclusive Extra. To do this you can text PICK to 150 or follow the steps below.
  1. Log in to My EE or use the EE app.
  2. Go to Menu > Plans, Inclusive Extras & add-ons.
  3. Select Inclusive Extras and follow the steps to select the pass.
What services are included with the Entertainment Data Pass?
Here are our chosen content provider apps covered by the Entertainment Data Pass. And we’re adding more all the time:
  • Amazon Prime Video
  • Apple Music
  • BBC iPlayer and BBC iPlayer Kids
  • BBC Sounds
  • Deezer
  • Global Player
  • ITV Player
  • My5
  • Netflix
  • Primephonic
  • SoundCloud
  • Spotify
  • Tidal
  • TNT Sports on discovery+
  • YouTube and YouTube Kids
Subscriptions to content providers are not included in the Entertainment Data Pass.
Are content subscriptions included in the Entertainment Data Pass?
No, the Entertainment Data Pass doesn’t give you subscriptions to the content providers.
Simply set up a subscription yourself first. Then watch and listen all you like without using any data. Exclusively with our Entertainment Data Pass.
Can I use the Entertainment Data Pass if I have no data allowance left in my plan?
No, if you’ve run out of data on your plan then the Entertainment Data Pass won’t work. You’ll need to buy a data add-on to continue using the pass or upgrade to a new plan with more data.
Where can I use the Entertainment Data Pass?
You can use the Entertainment Data Pass in the UK and anywhere your plan allows for inclusive roaming. That means you can use the pass in all EU member countries.
Content within the apps included in the Entertainment Data Pass might differ between countries due to entertainment rights agreements.
How do I remove my Entertainment Data Pass?
  3. Select Inclusive Extras and follow the steps to remove the pass.
Or you can text SWAP to 150.
Need more help?
  • EE app
    One little tap for complete control and all the help you need
    Get all the help and support you need via the EE Community
  • Need help? Contact us
    Contact us and follow the easy steps to resolve your query
