How to set up your eSIM using the QR code
Apple iPhone
Apple iPhone
Accept cookies to view this content.
How to set up your iPhone eSIM using the QR code
To get your iPhone eSIM set up, you can use the handy QR code we’ll have sent you. To find out how to do it, either watch the video or follow the step-by-step guide below.
Please note: you must be connected to Wi-Fi for it to work.
Step by step guide
  1. Connect to Wi-Fi – you must do this for it to work
  2. Go to Settings
  3. Go to Mobile Service or Mobile Data depending on what your iPhone shows
  4. Select Add eSIM or Setup Mobile Service – again, depending on what your iPhone shows
  5. Select Use QR Code
  6. Scan the QR code with your camera
  7. Follow the instructions to set up your eSIM
Please note: some iPhones have slightly different steps.
You can assign a name to each line and choose which lines are the default ones for data, and for calls and messages. Just go to Settings > Mobile Service or Mobile Data > Default Voice Line or Mobile Data.
To minimise loss of service, select your new eSIM as your default voice line, and the default for mobile data. You can easily change these later if you want.
How to reuse your iPhone eSIM using the same QR code
Our QR codes can now be reused up to three times, as long as you can delete the eSIM from the phone you’re currently using it on.
If you no longer have that phone, you will need to order a new eSIM. Please contact your mobile administrator to get help with this.
To reuse the QR code:
  1. Make sure you’re connected to Wi-Fi before deleting the eSIM from the phone you’re currently using it on
  2. Delete the eSIM - you can do this from the Mobile Data or Mobile Service menu within your settings
  3. Follow the step by step guide above
Setting up your iPhone eSIM - FAQs
What happens if I can’t scan my QR code with my iPhone?
You can use your iPhone to manually enter the information from the QR code. Here's how:
  1. Go to Settings
  2. Go to Mobile Service or Mobile Data – depending on what your iPhone shows
  3. Select either Add eSIM or Set up Mobile Service – again, depending on what your iPhone shows
  4. Select Use QR Code
  5. Select Enter Details Manually
  6. For SM-DP+ Address enter ee.pr.go-esim.com
  7. For Activation Code, enter your unique code on your eSIM pack – you’ll find it below the pack's setup instructions.
  8. Leave the Confirmation Code field blank
Can I use my QR code more than once?
Yes, QR codes can be reused up to three times on different phones or the same phone. To reuse your QR code, ensure you are connected to Wi-Fi before deleting the eSIM profile from the phone you’re currently using it on.
Which line are my calls on?
Initially all your contacts will be assigned to the default voice line you chose during set up. You’ll see an indicator within each contact that gives you the option to change which line you use for that contact.
If you're entering a phone number straight into the keypad, you can choose which line calls that number using the options on the screen.
When you receive incoming calls, you’ll see a call indicator to show which line is receiving the call. The indicator is the first letter of the name you assigned to each line. So, if the labels you’ve used are called Personal and Business, then the call indicator is P or B.
Can I use iMessage and Facetime on both lines?
From iOS 13 onwards, both lines can be used for iMessage and Facetime. You can manage this in Settings > Messages > Send & Receive.
Can I use data when I'm on a call?
If you're taking a call on the line that's not your default data line, data won't work unless you switch on Mobile Data Switching.
To do this go to Settings > Mobile Data > Mobile Data Switching and it will automatically switch lines for mobile data when you're on a call. It’s the easy way for you to talk and use data at the same time.
How to set up your Samsung eSIM using the QR code
To get your Samsung eSIM set up, you can use the handy QR code we’ll have sent you. To find out how to do it, either watch the video or follow the step-by-step guide below.
Please note: you must be connected to Wi-Fi for it to work. You’ll also need the latest software downloaded on your Samsung phone.
Step by step guide
  2. Go to Settings
  3. Go to Connections
  4. Go to SIM card manager
  5. Select Add mobile plan
  6. Select Scan carrier QR code and take a picture of the QR code on the eSIM pack – your camera will automatically open
  7. Confirm by pressing Register and then OK
If this is a second SIM for your Samsung phone, you'll have the option to assign a name and icon for each phone number. You can also choose what phone numbers or plans are used for your data and voice messages.
Please note: some Samsung phones have slightly different steps.
How to reuse your Samsung eSIM using the same QR code
  2. Delete the eSIM – you can do this from the SIM card manager menu within your settings
Setting up your Samsung eSIM – FAQs
What happens if I can’t scan my QR code with my Samsung phone?
You can use your Samsung phone to manually enter the information from the QR code. Here's how:
  1. Connect to the internet on Wi-Fi or Mobile Data
  2. Go to Settings
  7. Rather than scan the code, select Enter activation code
You’ll then need to type two things on one line:
  • LPA:1$ee.pr.go-esim.com$
  • Plus the unique 32-digit activation code on your eSIM pack
So if your activation code was ABCDEF1234567890ABCDEF1234567890 you’d type:
  • LPA:1$ee.pr.go-esim.com$ABCDEF1234567890ABCDEF1234567890
How to set up your Samsung phone for two SIMs
You can set up a Samsung Galaxy Dual SIM device with a combination of:
  • Two SIM cards
  • A SIM card and an eSIM
  • A MicroSD card and an eSIM or SIM card (except for the Samsung Galaxy Z Flip)
Each SIM will have a different number. If you have an unlocked device, you can also:
  • Have two SIMs on different networks (for example for a work number)
  • Insert a local SIM if you're travelling abroad
  • Manage what number to use for calls, messages, data, voice, and apps
Choose a SIM for calls, messages and data
To choose the SIMs, phone plans and numbers that are used for calls, messages and data, go to Settings > Connections > SIM Manager > Preferred SIMs.
Your phone will alert you if you try and make a call from your non-preferred SIM.
You can’t have two active calls at the same time. So, if you’re on the phone and your other number receives a call, then that incoming call goes through to voicemail. You can set calls to be forwarded from one line to another.
Messaging apps
Dual Messenger lets you create duplicate applications for messaging applications (like Skype or WhatsApp) for each number. Head to Settings > Advanced features > Dual Messenger.
Android
Android
How to set up your Android phone eSIM using the QR code
To get your Android eSIM set up, you can use the handy QR code we’ll have sent you. To find out how to do it, either watch the video or follow the step-by-step guide below.
Step by step guide
  2. Go to Settings
  3. Go to Network and internet
  4. Go to SIMs
  5. Select Add more
  6. Depending on your Android device, select either Download a SIM instead? or Don't have a SIM card?
  7. Scan the QR code with your camera. Once recognised, your eSIM will automatically begin downloading
How to reuse your Android eSIM using the same QR code
  2. Delete the eSIM – you can do this from the SIMs menu within your settings
Setting up your Android eSIM – FAQs
What happens if I can’t scan my QR code with my Android phone?
You can use your Android phone to manually enter the information from the QR code. Here's how:
  1. Go to Settings
  2. Go to Network and Internet
  3. Go to SIMs
  4. Select Add more
  5. Depending on your Android phone, select either Download a SIM instead? or Don’t have a SIM card?
  6. When you’re prompted to scan the QR code, select Need help?
  7. Select Enter it manually
So if your activation code was ABCDEF1234567890ABCDEF1234567890, you’d type:
How to switch between SIMs on your Android phone
You can easily switch between SIMs on your Android phone:
  1. Go to Settings
  2. Go to Mobile network
  3. Go to Operator
  4. Then just select the SIM you want to use
Need more help?
  • EE app
    One little tap for complete control and all the help you need
    Get all the help and support you need via the EE Community
  • Need help? Contact us
    Contact us and follow the easy steps to resolve your query
