Which iPhone XS size is best for your business?
When you’re choosing the best iPhone for your business, it’s fair to say size matters. But is bigger always better? Here we’ll compare how the iPhone XS measures up against other iPhone models to see which one will be best for your business.
iPhone XS dimensions
iPhone XS features an impressive, 5.8-inch Super Retina display, picking up from where the game-changing iPhone X left off. The actual handset is 143.6 mm tall, 70.9 mm wide and 7.7 mm deep, or in inches, that’s 5.65” x 2.79” x 0.3”.
The iPhone XS owes its sleek design to the most durable glass ever in a smartphone, paired with precision-machined, surgical-grade stainless steel. Reassuringly solid, it weighs in at 177 grams, or 6.24 ounces in old money.
How does the iPhone XS measure up against other iPhones?
Right now at EE, there’s never been a greater choice of iPhone sizes for your business. The following table lets you compare which phones have the biggest screens, and which ones take up the most room in your pocket.
iPhone model
Screen size
Height
Width
Depth
Weight
XS
5.8 inches
5.65”
2.79”
0.3”
177 grams
XS Max
6.5 inches
6.2”
3.05”
0.3”
208 grams
XR
6.1 inches
5.94”
2.98”
0.33”
194 grams
X
5.8 inches
5.65”
2.79”
0.3”
174 grams
8
4.7 inches
5.45”
2.65”
0.29”
148 grams
Is the iPhone XS big enough for business users?
With its edge-to-edge display, the screen on the iPhone XS is over an inch larger than the iPhone 8, despite being only a tiny fraction larger overall. That means it still fits neatly into your hand, but makes it easier to manage your emails, open documents, surf the web and more.
Of course, if you want the largest screen possible, you want the iPhone XS Max. Measuring in at 6.5 inches, corner to corner, it’s the closest thing you can get to a tablet, without actually carrying a tablet. It’s still portable enough to hold in your hand with ease, but you’ll need pretty large pockets to carry it comfortably.
But let’s not forget the iPhone XR. Launched a couple of weeks after the iPhone XS and iPhone XS Max, its 6.1-inch screen is a decent size compromise. It’s a wise choice of iPhone for budget-conscious businesses, because although it shares many of the powerful features of the XS models, it’s the cheapest of the three.
If you’d like to read more about the iPhone XS size and dimensions, visit the iPhone XS product page today.
Need more help?
  • EE app
    One little tap for complete control and all the help you need
    Get all the help and support you need via the EE Community
  • Need help? Contact us
    Contact us and follow the easy steps to resolve your query
