HELP CONNECTING YOUR ANDROID DEVICE TO Wi-Fi
Having trouble connecting your Android device to Wi-Fi? Either look at our easy-to-follow guide on how to connect to a Wi-Fi network
or try these quick fixes:
Switch on Wi-Fi on your Android device
These steps work for most Android devices, but some may have different ways to switch on Wi-Fi.
- Open Settings
- In Wireless and Networks or Connections, select Wi-Fi
- Switch on Wi-Fi
Move into Wi-Fi range
If none of the bars are showing in the Wi-Fi connection icon at the top of your screen, you’ve no Wi-Fi signal — try moving closer to the Wi-Fi router for a stronger connection.
Restart the Wi-Fi router
These steps work for most routers:
- Unplug the router’s power source.
- Wait 30 seconds.
- Plug the power source back in again.
- When the lights come back on the router has restarted.
For full instructions on restarting your router check the manual.
If you still can’t connect your Android device to Wi-Fi, you may need to contact the internet service provider for your router.
