CONNECT YOUR iPHONE TO WI-FI
When your iPhone is connected to a Wi-Fi network you don’t use your EE data.
It’s easy to get connected, either use our guides on how to connect to a Wi-Fi network
or follow these simple instructions:
  1. On your iPhone home screen, go to Settings > Wi-Fi
  2. Switch on Wi-Fi, and your iPhone will automatically find all the available Wi-Fi networks.
  3. Select the Wi-Fi network you want to join (you may need to enter a password for the network or agree to terms and conditions).
  4. When you’re connected, you’ll see a blue tick next to the network’s name. You’ll also see the Wi-Fi icon in the top-right of your iPhone’s screen.
Having problems using Wi-Fi? Check out Wi-Fi on your device
Need more help?
  • EE app
    One little tap for complete control and all the help you need
    Get all the help and support you need via the EE Community
  • Need help? Contact us
    Contact us and follow the easy steps to resolve your query
