The BT Sport app is closing on 12 October 2023.
For more information on how to view sports, go to our help page.
4G SPEED
If you want to know whether 4G is faster than 3G, the simple answer is yes - and usually in a knock-your-socks-off way.
We're not keen on too much technical jargon here at EE, but it could be as quick as ADSL broadband at home - while you're out and about.
Sounds good... so how quick is it?
There isn't a simple answer, unfortunately, as 4G performance depends on things like...
  • What device you're using
  • How near you are to a 4G mast
  • The number of people on the network
Brace yourself for some geek-speak...
Here's the technical bit. Average 4G download speeds are likely to be between 8 and 10 megabits a second (Mbit/s), with possible instances of up to 40 Mbit/s.
Typical upload speeds are between 5-6Mbit/s, with possible instances of up to 15Mbit/s.
Another technical word that might help make this 4G thing clearer is latency - the time it takes the network to respond to your action.
Typical 4G latency is only 60-70 milliseconds (ms), while 3G latency is typically 100-125ms. You can really appreciate the difference if you're flicking through webpages or playing online action games.
Need more help?
  • EE app
    One little tap for complete control and all the help you need
    Get all the help and support you need via the EE Community
  • Need help? Contact us
    Contact us and follow the easy steps to resolve your query
