EE BUSINESS PAY MONTHLY ADD-ONS
Add-ons are additional bundles of things like minutes, messages, data or services that you can buy.
You’ll see the add-ons on your bill and they frequently give you better value compared to standard rates. Add-ons can be a one-off payment or spread over the length of your contract.
What type of add-ons can I buy?
These are the add-ons we’ve got for you:
The easiest way to see all of the available add-ons is to log in to My EE:
- Login to My EE
- Go to Add-ons & Benefits
- In Device, select the number you’d like to view the add-ons for
- Go to Get more add-ons to see the available add-ons
You can find out more about all of our add-ons in our price guide.
EE Price Guide for Small Business Customers (.pdf 289 KB)
How do I buy add-ons?
It’s easy to buy an add-on through My EE. When you’ve bought an add-on we’ll start your allowance immediately.
Buy add-ons using the EE app
- Select Plan & add-ons from the main menu and select the Add-ons tab
- Select Get more add-ons and choose the add-ons you want to buy
- Select Get Add-on and then Confirm to buy
Buy add-ons using the My EE website
- Login to My EE
- Select Add to choose the add-on you want
- Select Yes, add this add-on to agree
How do I manage my active add-ons?
You can check your active add-ons using My EE. Most of our add-ons stay active, until you choose to remove them.
Remove add-ons using the EE app
- Select See your add-ons
- Choose the add-on you no longer want and select Remove this add-on
Remove add-ons using the My EE website
- Login to My EE
- Select Currently active add-ons
