LONDON UNDERGROUND WIFI - COOKIES
Cookies allow us to recognise your device automatically when you enter a station. They’re regularly used by websites and WiFi connections to identify users.
To enable cookies, just follow these steps for iPhones, iPads and BlackBerry and Android smartphones. For all other devices, please check your user manual which you’ll be able to find on the manufacturer's website.
iPhone / iPad
1. Open Settings and tap on Safari.
2. Under Privacy, tap on Accept Cookies and select From visited.
If this process doesn’t work, try clearing your cookies and data:
2. Under Privacy, tap on Clear Cookies and Data.
BlackBerry
Cookies are automatically enabled on BlackBerry devices, but you may need to clear your old cookie data. To do this, just follow these steps:
1. On the homescreen, click Browser.
2. Display the menu and select Options.
3. Click Cache Operations.
4. Click Clear History.
5. Click Clear under the headings Content Cache, Pushed Content and Cookie Cache.
Android
1. Open your main menu and launch Internet.
2. Open the menu within the browser and choose Settings and then Privacy & Security.
3. Make sure the box next to Accept Cookies is ticked.
3. Click on Clear all Cookie Data.
Windows Mobile
Cookies are automatically enabled on Windows Mobile devices. But you can check by following these steps:
1. Click on your browser to launch it.
2. Select Options.
3. Select Allow cookies on my phone.
Need more help?
  • EE app
    One little tap for complete control and all the help you need
    Get all the help and support you need via the EE Community
  • Need help? Contact us
    Contact us and follow the easy steps to resolve your query
