LONDON UNDERGROUND WIFI - HOW TO CONNECT
It's easy to connect to WiFi on the London Underground
Only devices with compatible EE SIMs can access the London Underground WiFi using EE WiFi hotspots. Follow the set-up instructions for your device below:
On Apple devices:
- make sure you have iOS 7 or above installed
- switch on your WiFi - you'll then automatically connect to EE WiFi
On compatible Android devices:
- once underground, turn on your WiFi
- select EE WiFi-Auto from the list of networks
- set the ‘access method’ to EAP
- set your ‘EAP method’ to SIM
