LONDON UNDERGROUND WIFI - HOW TO CONNECT
It's easy to connect to WiFi on the London Underground
Only devices with compatible EE SIMs can access the London Underground WiFi using EE WiFi hotspots. Follow the set-up instructions for your device below:
On Apple devices:
  • make sure you have iOS 7 or above installed
  • switch on your WiFi - you'll then automatically connect to EE WiFi
On compatible Android devices:
  • once underground, turn on your WiFi
  • select EE WiFi-Auto from the list of networks
  • set the ‘access method’ to EAP
  • set your ‘EAP method’ to SIM
Need more help?
My EE app
Get 24/7 support through the My EE app
EE Community
Get support via the EE Community
Need help? Contact us
Follow the easy steps to resolve your query
