Help connecting your Android device to WiFi
Having trouble connecting your Android device to WiFi? Try our quick fixes:
Switch on WiFi on your Android device
These steps work for many Android devices, but some may have different ways to switch on WiFi.
  • Open your Settings
  • In Wireless and Networks or Connections, tap Wi-Fi
  • Switch on WiFi
Move into WiFi range
Check the WiFi connection icon at the top of your screen. If none of the bars are showing, you have no WiFi signal. Try moving closer to the router and you should get stronger WiFi.
Restart the WiFi router
Please check the router manual for instructions on restarting. Here are some basic steps to try:
  • Unplug the router so all the lights go out
  • Wait 30 seconds
  • Plug the router in again
  • When the router has restarted, the lights will come on again
If you still can’t connect your Android device to WiFi, you may need to contact the internet service provider for the router.
Need more help?
My EE app
Get 24/7 support through the My EE app
EE Community
Get support via the EE Community
Need help
Follow the easy steps to resolve your query
